jconway1006
Mar 21, 2020Aspirant
HP Printer and RAX120
Hey All, So a few weeks ago I got the RAX120 Went to print something today via Wifi and noticed my printer wasn't connected. HP Laserjet Pro 200 (M251 I believe) Pretty sure its a wifi setting...
Newfiedrool
Mar 23, 2020Virtuoso
I take it you have gone through the WiFi wizard setup and reading it can't be used whilst connected to a computer and wirelessly at the same time.
jconway1006
Mar 23, 2020Aspirant
It was connected to USB but I unplugged rebooted PC and Printer and tried WIFI again and it still doesn't work.
- NewfiedroolMar 23, 2020Virtuoso
Have you the manual for the printer?
- jconway1006Mar 23, 2020Aspirant
I'm sure I can download it. But I'll say this. Only change I made to my network in a very long time was this router. SSID and passwords all the same on this router vs my older one. Which I still have. Again its not to important I get this going.
I'm actually an IT guy as well and its my nature to try and get this working but I don't print much. And still can from my PC. Just a nice added bonus to print Wifi when needed thats all.
https://support.hp.com/gb-en/product/hp-laserjet-pro-200-color-printer-m251-series/5097632
you need to run the setup wizard. I've linked the page above so you can check device drivers and obtain the manual.
- jconway1006Apr 02, 2020Aspirant
So my router took a firmware update two days ago and I just noticed this morning that my printer is on WIFI again! LOL
- michaelkenwardApr 03, 2020Guru - Experienced User
The result of "action at a distance".
- onvisonSep 01, 2020Tutor
I have the same Pinter Laserjet 200 and just got the AX12 and I have that same annoying problem. Everything is connected except my printer. It tells me that the Security passcode is incorrect.
I also work in IT and this is super annoying.
Ive done manual ip settings, reserved ips, and firmware updates etc. How did you fix the problem? Thanks
WIFI protected setup went through successfully on the Rounter both in Pin mode and puch button mode but also both ways displayed Failed to connect from the printer screen. For some reason this printer does not like this router!
Problem is definitely coming from the security types of the AX12, when I remove the security completely the printer connects, but I cant keep the network open so Im not sure what other option there is ( there isnt a firmware update available for the printer or router)
