davidhickey27
Jun 12, 2024Aspirant
Huawei ONT OptiXstar HG8010Hv6
Hi All With an optical fibre installed on an H/// ONT, is it possible to connect my RAX80 directly via LAN the provider has its WIfi router that does not support modem mode? Any help appreci...
- Jun 12, 2024
Same applies to the ONT.
davidhickey27
Thank you, that is a very kind and prompt response, but there is no modem only the ONT?
Jun 12, 2024Guru - Experienced User
