Jsand3030
Nov 13, 2022Aspirant
I’ve just purchased this rax120v2 v1.2.8.40 firmaware
I’ve just purchased this rax120v2 v1.2.8.40 firmaware less than a month ago and from the start am getting wifi drops multiple times a day. I don’t know why else to do but try and return this crap.
Nov 13, 2022Guru - Experienced User
What is the first 3 characters of the routers serial number seen on the sticker under the router?
Be sure your using a good quality LAN cable between the modem and router. CAT6 is recommended.
Jsand3030
6JY
This isn’t the Comcast modem as I’ve tested connections to both routers and Comcast’s is stable.
