baneand
Apr 10, 2023Aspirant
I also have this router AX120v2 and have added latest beta firmware installed
I also have this router AX120v2 and have added latest beta firmware installed which has fixed random rebooting (so far 2 days working good). But I have 5GHz wifi problem - occasionally it just doesn'...
Apr 10, 2023Guru - Experienced User
Be sure your using a good quality LAN cable between the modem and router. CAT6 is recommended.
What channels are you using? Auto? Try setting manual channel 1, 6 or 11 on 2.4Ghz and 40 to 48 channel on 5Ghz.
Has a factory reset and setup from scratch been performed since last FW update? A complete pull of the power adapters for a period of time after the factory reset then walk thru the setup wizard and setup from scratch with a wired PC and web browser. Recommend setting the default DHCP IP address pool range to the following after applying and a factory reset: 192.168.#.100 to 192.168.#.200.
https://kb.netgear.com/24089/How-do-I-specify-the-pool-of-IP-addresses-assigned-by-my-Nighthawk-router
baneand
My internet modem is Cisco EPC3928, I am using it for last 8 years with another asus router without problems. Cable is was CAT5 but from what I tested these days only wifi is problematic. I switched now to CAT6
Channel on 5 GHz is 44,
I did try factory reset just now and set the range of ip address from .100 - .200 but same behavior - basically communication drops each minute or two for couple of seconds and then it gets running good again.
