baneand
Apr 10, 2023Aspirant
I also have this router AX120v2 and have added latest beta firmware installed
I also have this router AX120v2 and have added latest beta firmware installed which has fixed random rebooting (so far 2 days working good). But I have 5GHz wifi problem - occasionally it just doesn'...
baneand
My internet modem is Cisco EPC3928, I am using it for last 8 years with another asus router without problems. Cable is was CAT5 but from what I tested these days only wifi is problematic. I switched now to CAT6
Channel on 5 GHz is 44,
I did try factory reset just now and set the range of ip address from .100 - .200 but same behavior - basically communication drops each minute or two for couple of seconds and then it gets running good again.
Apr 10, 2023Guru - Experienced User
What happens if you disable AX mode on the router and also disable Smart Connect?
What are the current settings for Wireless settings under advanced tab/advanced settings?
Whats the first 3 characters of the routers series number in back?
