grsthegreat
Feb 02, 2023Tutor
i am having trouble accessing genmon generator monitoring rasburry pi unit
rax20 running version 1.0.11.112_2.0.77 i have a raspberry pi monitoring device called Genmon on my whole house generator. it is generating an ip address, that i can see on my router and has ...
- Feb 02, 2023
actually, the problem was in the Pi unit. i got it all resolved.
michaelkenward
Feb 02, 2023Guru - Experienced User
grsthegreat wrote:
everything worked ok until i rebooted the router.
It might help if you told people what the modem is in front of this router, if there is one. The make and model number could be useful. Is it, by any chance, also a router, with a set of LAN ports on the back?
The reason for asking is that a lot of people turn up here trying to put a router behind a modem that is also a router. That can complicate troubleshooting.
