Retired_Member
Aug 26, 2019I can not find a way to turn WPS off on the RAX80
Was just going though the settings and one thing that should be able to turn off is the WPS feature. Am I over looking this?
michaelkenward
Aug 27, 2019Guru - Experienced User
There is support for the RAX80, including a manual, at the end of this link:
>>> RAX80 | Product | Support | NETGEAR<<<
See the section Specify WPS Settings.
If you want to disable the button, you may be out of luck.
Any reason why you want to do this? Maybe there are other ways of achieving the required outcome.
Retired_Member
Aug 27, 2019Should be able to turn this off like most routers.
It can or is seen as a security risk.
- ablickleAug 27, 2019Guide
I think this is what you are looking for:
Go to:
Advanced Setings
Advanced Set Up
Wireless Settings
Under WPS settings, uncheck "Enable Router's PIN"
According to the help center:
Enable Router's PIN
You can configure the router's wireless settings or add a wireless client through WPS using the router's PIN only when the PIN is enabled.
- michaelkenwardAug 27, 2019Guru - Experienced User
I suggested that, but apparently the quest is to disable the WPS button.
No idea why.
missed that on your original reply... seems like the option would do the trick sufficiently, but... :)
- Retired_MemberAug 27, 2019I will try this suggestion when I get home this evening just don’t like having the button available for anybody that connect to the network I have a guest network specifically for people visiting.
