Retired_Member
Aug 26, 2019I can not find a way to turn WPS off on the RAX80
Was just going though the settings and one thing that should be able to turn off is the WPS feature. Am I over looking this?
Retired_Member
Aug 27, 2019Should be able to turn this off like most routers.
It can or is seen as a security risk.
ablickle
Aug 27, 2019Guide
I think this is what you are looking for:
Go to:
Advanced Setings
Advanced Set Up
Wireless Settings
Under WPS settings, uncheck "Enable Router's PIN"
According to the help center:
Enable Router's PIN
You can configure the router's wireless settings or add a wireless client through WPS using the router's PIN only when the PIN is enabled.
- michaelkenwardAug 27, 2019Guru - Experienced User
I suggested that, but apparently the quest is to disable the WPS button.
No idea why.
- ablickleAug 27, 2019Guide
missed that on your original reply... seems like the option would do the trick sufficiently, but... :)
- Retired_MemberAug 27, 2019I will try this suggestion when I get home this evening just don’t like having the button available for anybody that connect to the network I have a guest network specifically for people visiting.
