Gabriel12
Dec 18, 2020Follower
I can not print after uppgrading firmware
I have a Epson WorkForce Pro WF-5690 and have been printing on it using the LAN-cable or Wifi. Suddenly it will not work and I got the message that the printer have a internal problem. I have re...
Dec 18, 2020Guru - Experienced User
so you got a message that the printer was having an internal problem. so you reset the printer and it doesn't function right. but you think its the router.
ANY other devices having issues?
If not, I'd contact the printer manufacturer for help with getting its lan functions working again.
