Scaff
Dec 05, 2022Aspirant
I cannot access the router from a pc
can anyone hrlp pls
i cannot access the router from a pc
if i follow the links from netgear saying use routerlogin.net or .com i just get a web page not the router login page.
Dec 05, 2022Guru - Experienced User
Press the reset button for 15 seconds then release. Have one wired PC connected then navigate to 192.168.1.1 to see if you can access the routers web page after about 1 minute.
Be sure your using a good quality LAN cable between the modem and router. CAT6 is recommended.
