Scaff
Dec 05, 2022Aspirant
I cannot access the router from a pc
can anyone hrlp pls
i cannot access the router from a pc
if i follow the links from netgear saying use routerlogin.net or .com i just get a web page not the router login page.
michaelkenward
Dec 05, 2022Guru - Experienced User
A reset is the nuclear option. Best avoided. There are plenty of other things to try first.
But what to try depends on what you have at your end.
What is this Netgear router?
And what is this webpage that you land on?
If you cannot login to your router | Answer | NETGEAR Support
What do you want to do on the router?
