Scaff
Dec 05, 2022Aspirant
I cannot access the router from a pc
can anyone hrlp pls
i cannot access the router from a pc
if i follow the links from netgear saying use routerlogin.net or .com i just get a web page not the router login page.
Scaff
sorry
VPN was causing an issue. got it sorted
thanks for replies
- michaelkenwardDec 05, 2022Guru - Experienced User
Well done. Certainly safer than going back to square one.
I was about to mark this as SOLVED – for the benefit of anyone who turns up later – but then wondered if a few more details might be useful.
Any tips for fellow victims?
- FURRYe38Dec 05, 2022Guru - Experienced User
Enjoy. 📡
Scaff wrote:
sorry
thanks for replies
