strykerzr350
Dec 02, 2023Guide
I cannot get my maximum speed with my RAXE500
So I got Gig extra with Xfinity and its supposed to be 1400 down and 40 up. On my download speed test I cannot get all of the 1400 using the speed test function on the router. I have the modem con...
strykerzr350
Dec 02, 2023Guide
I am not seeing it from the PC that I am testing it from. I am seeing the slow speeds from the speed test app built into the router. On my PC I get 940 to 920 down, which is expected.
For instance. Screenshot provided. I was told by someone not on this forum that consumer routers are nothing but garbage ARM CPUs that cant do much.
Not even now am I getting a gig of speed.
Dec 02, 2023Guru - Experienced User
And that result could be use to conditions, speed test site and ISP services as well.
I usually don't test with on board speed test. I use ooklas installable speed test app on a wired PC.
- strykerzr350Dec 03, 2023Guide
When I test using my phone, it will top out to about 1200 down, but will start tapering to about 1000 to 900.
Samsung says the phone can do 2000 down and up using WiFi 6E. - FURRYe38Dec 03, 2023Guru - Experienced User
Depending on distance, noise and configuration, then seems like your phone is getting over 1Gb.
