Serkan-mx
Dec 03, 2022Aspirant
I have 2x1000 mb internet =2000mb internet
Hello I have 2x1000 mb internet I want to combine it and get 2000 mb internet as a single output ? Are these devices suitable for this? Rax120-Rax200 or is there a device you can recommend for m...
michaelkenward
Dec 03, 2022Guru - Experienced User
Manuals are always a good place to start.
Visit the support pages:
Support | NETGEAR
Feed in your model number and check the documentation for the hardware.
There you can read the specifications for these devices. Look at the Data Sheets.
The RAX200 claims:
Multi-Gig 2.5G Ethernet interface can be used for wired devices on LAN or for getting faster Multi-Gig Internet speed
Serkan-mx
Hello
Can you explain a little more in detail?
- michaelkenwardDec 03, 2022Guru - Experienced User
Serkan-mx wrote:
Hello
A question better aimed at you, I think.
As plemans suggests, a lot depends on what you are trying to do and what you are using on your network.
In many cases, getting 2000 Mbps would be useless. Most current LAN stuff maxes out at 1000 Mbps. This is bound to change over the years, but busting a gut to get there now may be pointless for most people.
- Serkan-mxDec 03, 2022Aspirant
Hello
Is there a defragmenter you would recommend? Router ?
thanks
