Serkan-mx
Dec 03, 2022Aspirant
I have 2x1000 mb internet =2000mb internet
Hello I have 2x1000 mb internet I want to combine it and get 2000 mb internet as a single output ? Are these devices suitable for this? Rax120-Rax200 or is there a device you can recommend for m...
Dec 03, 2022Guru - Experienced User
How exactly are you doing this 1000x2 setup?
Is it from 2x different ISP's?
Is it from a multi-port modem that supports lan port aggregation?
Also, how are you planning on using this? Do you have multigig devices on your network?
- Serkan-mxDec 03, 2022Aspirant
Hello
Is it from 2x different ISP's: Yes
There is a 2.5gb pc connecting the connection!!
I will download the file from the internet (movie-Game)
There is a network switch with 2.5 gb support
Will I do the defragmentation with these devices?
CM2000-> RBKE963B-> Trendnet TEG-S380-> GS716T->Thanks
- michaelkenwardDec 03, 2022Guru - Experienced User
CM2000-> RBKE963B-> Trendnet TEG-S380-> GS716T->Most unlikely.
combine two isps one network - Google Search – combine two isps one network
Not something you can do by slapping together bits of consumer network hardware,
- plemansDec 04, 2022Guru - Experienced User
You'd want to look at a router that supports dual wan capabilities. None of netgears consumer gear supports dual wan.
