Serkan-mx
Dec 03, 2022Aspirant
I have 2x1000 mb internet =2000mb internet
Hello I have 2x1000 mb internet I want to combine it and get 2000 mb internet as a single output ? Are these devices suitable for this? Rax120-Rax200 or is there a device you can recommend for m...
Serkan-mx
Hello
Can you explain a little more in detail?
michaelkenward
Dec 03, 2022Guru - Experienced User
Serkan-mx wrote:
Hello
A question better aimed at you, I think.
As plemans suggests, a lot depends on what you are trying to do and what you are using on your network.
In many cases, getting 2000 Mbps would be useless. Most current LAN stuff maxes out at 1000 Mbps. This is bound to change over the years, but busting a gut to get there now may be pointless for most people.
