Serkan-mx
Dec 03, 2022Aspirant
I have 2x1000 mb internet =2000mb internet
Hello I have 2x1000 mb internet I want to combine it and get 2000 mb internet as a single output ? Are these devices suitable for this? Rax120-Rax200 or is there a device you can recommend for m...
Serkan-mx
Hello
Is it from 2x different ISP's: Yes
There is a 2.5gb pc connecting the connection!!
I will download the file from the internet (movie-Game)
There is a network switch with 2.5 gb support
Will I do the defragmentation with these devices?
CM2000-> RBKE963B-> Trendnet TEG-S380-> GS716T->
Thanks
michaelkenward
Dec 03, 2022Guru - Experienced User
Most unlikely.
combine two isps one network - Google Search – combine two isps one network
Not something you can do by slapping together bits of consumer network hardware,
