jbuddy12
Apr 30, 2021Aspirant
I have a Netgear CM1100 and Nighthawk RAX75. Is there a compatible mesh system?
Is there a good mesh system compatible with my router? I don't want to buy another router to get the mesh? Is there a less expensive option too as Nighthawk mesh is so expensive.
- Apr 30, 2021
Any of them will work. but if if you're wanting ax then the EAX15, EAX20, EAX80 are all compatible.
Otherwise I usually recommend the triband EX7500, EX7700, EX8000 line.
jbuddy12
Which mesh extenders work with my set up? Netgear has one that is $379.00 which is quite expensive. Had I known when I bought this, I would have gotten the Nighthawk mesh with the router all in one. Same dollars. Now I am piece mealing together it seems.
Apr 30, 2021Guru - Experienced User
