Netgarovish
Nov 14, 2019Follower
I have a RAX120 running as an access point, but I cant seem to turn off its DHCP
For reasons I might go into a different time I am running a seperate firewall and router now, an using the rax120 as an accesspoint. It appears that the rax120 still is running a dhcp server and ...
Nov 14, 2019Guru - Experienced User
I guess my question is what IP address's are being handed out?
If the primary router is handling the ip addresses, they should be in the range specified by that router. If both the primary router and the RAX are handing out ip addresses, usually they're in another subnet. (primary 192.168.1.** and rax 192.168.0.** or something along those lines.
Where is it saying dhcp is turned on? in my attached devices page it shows the access control but nothing about dhcp.
