Darkatt
Sep 07, 2026Aspirant
I have an raxe300 connected to a cm3000
I have an raxe300 connected to a cm3000, and it says the internet speed is 470 mbps, when the computer is connected direct to the cm3000 it says the internet speed is 1149mbps. If I try to manually s...
Sep 07, 2026Guru - Experienced User
Be sure your using the multi-gig WAN/LAN port to connect to the CM3000 modem.
Default on the RAXE router uses the 1Gb yellow WAN port.
CAT6A STP cable is recommended between the RAXE and CM modem.
