Darkatt
Sep 07, 2026Aspirant
I have an raxe300 connected to a cm3000
I have an raxe300 connected to a cm3000, and it says the internet speed is 470 mbps, when the computer is connected direct to the cm3000 it says the internet speed is 1149mbps. If I try to manually s...
Darkatt
Sep 08, 2026Aspirant
Connected to the 2.5 gb wan port. The router will not allow me to select an internet speed on the QOS page of greater that 1000 mbps. Tha ACTUAL provisioning speed from my ISP is faster. Router speed test, ( Probably due to the server they are using), is 470 mbps, computer direct to modem gets 1149 mbps, but again, the router will not allow a manual speed selection of greater that 1000 mbps.
- FURRYe38Sep 08, 2026Guru - Experienced User
QoS is not really needed on ISP speeds 1GB or higher. I'd disable QoS, reboot the router then speed test.
- DarkattSep 08, 2026Aspirant
I realize that, but the QOS page is where the INTERNET BANDWIDTH is either calculated, or input. If you notice, I didn't select QOS, I am working at the place where it says I want to define my internet bandwidth.
NG may have only set the QoS input value to max out at 1GB. Since the default port was for the 1Gb port. May have not applied this to the Multi Gig port.
QoS isn't required for anything past 1GB. So you'll need to use it as is or disable it. I'd leave it disabled.
Besides the QoS database is 5 years old and would be no longer updated by NG.
