Darkatt
Sep 07, 2026Aspirant
I have an raxe300 connected to a cm3000
I have an raxe300 connected to a cm3000, and it says the internet speed is 470 mbps, when the computer is connected direct to the cm3000 it says the internet speed is 1149mbps. If I try to manually s...
Darkatt
Sep 08, 2026Aspirant
I know all that. all I want to do is MANUALLY setup my internet bandwidth, and the max speed it allows is 1000 mbps, and my actual bandwidth is 1150 mbps.
Sep 08, 2026Guru - Experienced User
And that's due to the 1Gb WAN and LAN ports. Nothing you can do about that.
Darkatt wrote:I know all that. all I want to do is MANUALLY setup my internet bandwidth, and the max speed it allows is 1000 mbps, and my actual bandwidth is 1150 mbps.
