olegeezer
Jul 31, 2024Guide
I have read some instructions on how to make another netgear router a secondary AP.
Hey everybody. I want to know the correct procedures to follow in setting up a second router as an AP in routerlogin.net. I have read other instructions of how to do it but I only want to do this onc...
olegeezer
Aug 18, 2024Guide
I got the problem fixed. The RAX120 is working as it should now.
Thanks, Matt
- FURRYe38Aug 18, 2024Guru - Experienced User
Glad you got it working. Be sure to save off a back up configuration to file for safe keeping. Saves time if a reset is needed.
Enjoy. 📡- olegeezerAug 18, 2024Guide
In google, it would allow me to save a backup file but not in Edge. What I learned was to click on the title "downloads" ant then save it. Worked great.
MS Edge can save the back up, just have to select KEEP IT as MS Edge seems to think the config file saves are not safe. 🙄
