olegeezer
Jul 31, 2024Guide
I have read some instructions on how to make another netgear router a secondary AP.
Hey everybody. I want to know the correct procedures to follow in setting up a second router as an AP in routerlogin.net. I have read other instructions of how to do it but I only want to do this onc...
olegeezer
Aug 18, 2024Guide
I got the problem fixed. The RAX120 is working as it should now.
Thanks, Matt
Aug 18, 2024Guru - Experienced User
Glad you got it working. Be sure to save off a back up configuration to file for safe keeping. Saves time if a reset is needed.
Enjoy. 📡
- olegeezerAug 18, 2024Guide
In google, it would allow me to save a backup file but not in Edge. What I learned was to click on the title "downloads" ant then save it. Worked great.
- FURRYe38Aug 18, 2024Guru - Experienced User
MS Edge can save the back up, just have to select KEEP IT as MS Edge seems to think the config file saves are not safe. 🙄
