Lucci
Jul 14, 2020Aspirant
i have the mk62 and the satellite won't connect to the router
I have the MR60 and one MS60 satellite and i do the re sync for the satellite and it is blue for about 3 seconds before going back to amber and when i use the wifi it is very laggy. When i try and up...
Christian_R
Jul 17, 2020NETGEAR Employee Retired
Hi Lucci,
You may factory reset your units by holding down on the reset button for 15+ seconds located on the back. After doing so, you should be able to run through the setup assistant again.
Christian
- LucciJul 17, 2020Aspirant
Christian_R wrote:Hi Lucci,
Christian
do i have to reset both or just the sattelite?
- Christian_RJul 20, 2020NETGEAR Employee Retired
Lucci - For now, I would suggest just factory resetting the satellite and attempt to re-sync it back to the router.
Christian
- ChrisARitzDec 16, 2020AspirantI’m having the same issue. The router and one satellite sync fine. The second satellite won’t sync.
I’ve done a hard reset on the router and both satellites.
The one that won’t syncs is amber after pushing the syncs buttons on both the router and satellite.
I’ve also done a 30/30/30 on the satellite.
Any suggestions?
