jetsetser
Jun 02, 2020Follower
i have the modem router c3000 , can i hook my nighthawk ax3000 to be the primary router?
trying to hook my night hawk ax3000 to my modem router combo netgear c3000. help!
Jun 03, 2020Guru - Experienced User
you can put the C3000 in modem only mode.
This allows you to use the AX3000 as primary router.
michaelkenward
Jun 04, 2020Guru - Experienced User
If you visit the support pages:
Support | NETGEAR
you can feed in your model number and find the documentation for your hardware.
Read the bit To cable your modem router to a router or gateway.
