bacin87
Aug 19, 2020Tutor
I have the RAX200 is the EAX80 the correct Extender for it?
I I have the RAX200 I have a older home that kills wifi will the EAX80 the correct Extender for it?
- Aug 20, 2020If you've got cat7 ran throughout the house and you're still within your return period on the RAX200, I'd return it and go with the orbi setup.
Reason why is orbi has single ssid function with roaming. And it supports a wired and/or wireless backhaul.
Versus the EAX80, when its hardwired in running in access point mode, doesn't function as a mesh device. It only functions as a mesh device in wireless extender mode.
Aug 20, 2020Guru - Experienced User
bacin87 wrote:I I have the RAX200 I have a older home that kills wifi will the EAX80 the correct Extender for it?
there's many extenders that would work. I'm a fan of the triband extenders (there isn't an AX triband extender yet).
but the EAX80 would work with it. Would it work well in your home? Its tough to tell off the minimum info you gave. some older homes have plaster lathe walls or other materials that block wifi very well. I thats the case, sometimes its better to check into powerline devices, moca adapters, or even full mesh systems.
What is your home made of?
What size is it?
- bacin87Aug 20, 2020TutorYou're correct it is plaster lathe walls so for majority of the home I ran cat7. The house had knob and tube that's being replaced so powerline didn't work well after the rest of my house is rewired which will be done over the next two months I'll look at my power line adapter options.
- plemansAug 20, 2020Guru - Experienced UserIf you've got cat7 ran throughout the house and you're still within your return period on the RAX200, I'd return it and go with the orbi setup.
Versus the EAX80, when its hardwired in running in access point mode, doesn't function as a mesh device. It only functions as a mesh device in wireless extender mode.- bacin87Sep 18, 2020TutorI was already outside of the return. So I think I'll get it as a wireless mesh device just support certain areas of my house that I can't run wired and everything else will be wired through my switch into my router.
