Murph_Games
Nov 01, 2023Follower
I lose internet intermittently
I'm having the same issue. I have wireless turned off. I have pinged google and the router at the same time on a wired connection. I lose internet intermittently, but, the ping to the local router st...
michaelkenward
Nov 02, 2023Guru - Experienced User
Maybe, maybe not.
You have joined in on an existing conversation that may or may not have anything to do with your problems.
There is also a good chance that the official support team is busily monitoring new conversations and may miss your addition to this one.
If you do want help with your problem, check previous stuff that may be related then start your own discussion.
If you do decide to ask a question, you should provide more details and your own version of the information that the forum suggests that you provide. For example, as this is a router, it helps to know what modem you are using and the various things that you have tried to fix the problem.
