arturox
Aug 07, 2021Tutor
I need a step by step guide to configure this AX1800 WiFi 6 Router
My old netgear router is on its last legs, so I've purchased an AX1800 WiFi 6 Router to replace it... It will only be used in Wired (Ethernet cable) mode. Unfortunately I cannot configure it as it a...
- Aug 15, 2021
To answer the email I received. "Did it solve your problem?"
Unfortunately not with a Netgear product, which is quite sad as my last two Modem Routers were Netgear.
I took the advice from a friend and am using another product.
Ax
arturox
Aug 07, 2021Tutor
I see no way here to re-edit a post?
The name on my last post should be Arturox. :-)
Ax
