arturox
Aug 07, 2021Tutor
I need a step by step guide to configure this AX1800 WiFi 6 Router
My old netgear router is on its last legs, so I've purchased an AX1800 WiFi 6 Router to replace it... It will only be used in Wired (Ethernet cable) mode. Unfortunately I cannot configure it as it a...
- Aug 15, 2021
To answer the email I received. "Did it solve your problem?"
Unfortunately not with a Netgear product, which is quite sad as my last two Modem Routers were Netgear.
I took the advice from a friend and am using another product.
Ax
Aug 07, 2021Guru - Experienced User
What actual router did you buy? AX1800 is a speed.
I'd start by factory resetting it. Push and hold reset for 7-15 seconds while its powered on.
That'll get you to the defaults login/password.
Default login: admin
default password: password
when you first login with those, it'll ask you to change the password and setup the password recover feature.
You can find guides at netgear.com/support/
type in the actual model number and it'll take you to guides, manuals, firmware. etc.
