arturox
Aug 07, 2021Tutor
I need a step by step guide to configure this AX1800 WiFi 6 Router
My old netgear router is on its last legs, so I've purchased an AX1800 WiFi 6 Router to replace it... It will only be used in Wired (Ethernet cable) mode. Unfortunately I cannot configure it as it a...
- Aug 15, 2021
To answer the email I received. "Did it solve your problem?"
Unfortunately not with a Netgear product, which is quite sad as my last two Modem Routers were Netgear.
I took the advice from a friend and am using another product.
Ax
antinode
Aug 08, 2021Guru
> [...] many of the terms of reference about networking are arcane to
> me... [...]
Do you expect anyone here to guess what you don't understand?
> [...] the most recent one is dead to the internet, [...]
It's a modem+router. Does your (non-)description mean that its modem
section is not working, or that its router section is not working?
> [...] drops out quite often [...]
> [...] so I don't think in this instance your suggestion would work.
Based on what actual evidence?
> [...] I'm still looking into a replacement Modem router.
I doubt that you'll find much new stuff from Netgear in the DSL
modem+router (or DSL modem) category.
arturox
Aug 08, 2021Tutor
Ax wrote:> [...] I'm still looking into a replacement Modem router.
You are correct it seems, so I've asked around amongst friends to see what they suggest.
Ax
- arturoxAug 08, 2021Tutor
I guess my time here is finished, but I do thank you for the advice and suggestions.
Ax
- arturoxAug 15, 2021Tutor
Ax
