Tanner8230
Nov 21, 2022Aspirant
I need help
Hi, I believe I have the netgear nighthawk rax120 I have mediacoms modem don’t have the name of that one. The router is in bridge mode because I put it there so I could connect two routers but I coul...
Nov 21, 2022Guru - Experienced User
Wire connect a PC to the router and factory reset the router using the back push pin button. Hold it in for 10 seconds then let go. Then log in to routerlogin.com or 192.168.1.1 using a wired PC and web browser and walk thru the setup wizard. Be sure write down all important information for safe keeping later on.
Tanner8230
I don’t see a reset button
- FURRYe38Nov 21, 2022Guru - Experienced User
Look in back of the router where all the plug ports are at. Look for a little hole marked "Reset". Use a paper clip or a small pin to push this button. You should feel a bump when you push in. Hold for 10 seconds then release.
Look at the online user manual for your router to see where this reset button is if you need additional help and information.
- Tanner8230Nov 21, 2022AspirantOk I will try appreciate it 🙂
- Tanner8230Nov 21, 2022AspirantActually one more thing, how do I know if my port forwarding worked?
