ketcham
Dec 09, 2020Initiate
I need to remove Netgear Armor from Nighthawk RAX35v2 Router. It's garbage worm and I want it gone
I just bought a Nighthawk RAX35v2 and it forced this Armor crap on my Router. Nobody wants this junk and I need it completely removed or I will return this paper weight promptly!!! You shouldn't ha...
roger1955
Dec 11, 2020Apprentice
No worries,
You just have to do a factory reset, it is the only way. When you do, don't enable it again.
