ketcham
Dec 09, 2020Initiate
I need to remove Netgear Armor from Nighthawk RAX35v2 Router. It's garbage worm and I want it gone
I just bought a Nighthawk RAX35v2 and it forced this Armor crap on my Router. Nobody wants this junk and I need it completely removed or I will return this paper weight promptly!!! You shouldn't ha...
Razor512
May 29, 2021Prodigy
Do a factory reset and then use your web browser to do the setup and NOT the nighthawk app.
That will keep the armor service from being enabled.
