Slani
Oct 20, 2022Aspirant
I ordered the RAX120 yesterday
Hello everybody, I ordered the RAX120 yesterday (to replace my R7000, which probably got bricked, the power led is just solid amber and nothing helps with that), after which I discovered that many pe...
michaelkenward
Oct 20, 2022Guru - Experienced User
Slani wrote:
Just to be sure: V1 is alright, there are no users complaining about it rebooting? (if there are some, should I cancel the order immediately?) I bought RAX120-100EUS, is that V1?
Given Amazon's. and Netgear's, history of not keeping their websites up to date, you won't know which hardware version you will receive until it turns up.
Just for fun, you could try the usual recovery process.
How to upload firmware to a NETGEAR router using Windows TFTP | Answer | NETGEAR Support
This isn't the easiest operation, so if you are forced to use it, you could try a web search to find videos that guide you through the process. Here's one:
Different device, same approach.
