Slani
Oct 20, 2022Aspirant
I ordered the RAX120 yesterday
Hello everybody, I ordered the RAX120 yesterday (to replace my R7000, which probably got bricked, the power led is just solid amber and nothing helps with that), after which I discovered that many pe...
Oct 20, 2022Guru - Experienced User
You will find a lot of users with issues on here and the reviews because its where users go with issues. (the forums and negative reviews)
But there's a lot of users that didn't have issues and it works fine on. I'd just follow the wait and see approach. Yours might be perfectly fine. If not, I've heard rumors of a firmware in the works to fix it. If you have issues, I'm sure you can get that firmware.
