Slani
Oct 20, 2022Aspirant
I ordered the RAX120 yesterday
Hello everybody, I ordered the RAX120 yesterday (to replace my R7000, which probably got bricked, the power led is just solid amber and nothing helps with that), after which I discovered that many pe...
Oct 20, 2022Guru - Experienced User
When your 120 arrives, post the first 3 characters only of the serial number seen on the bottom sticker.
- michaelkenwardOct 20, 2022Guru - Experienced User
Usually also on the box. No need to even open it.
- FURRYe38Oct 20, 2022Guru - Experienced User
FYI, I've noticed that sometimes the numbers on the box can be covered over with other stickers that can't be removed coming from Amazon and having a used or refurb status. So if you find the box has a sticker or other stickers over this labeled box area, you'll need to visually look at the routers sticker. This should NOT be covered.
