Slani
Oct 20, 2022Aspirant
I ordered the RAX120 yesterday
Hello everybody, I ordered the RAX120 yesterday (to replace my R7000, which probably got bricked, the power led is just solid amber and nothing helps with that), after which I discovered that many pe...
michaelkenward
Oct 20, 2022Guru - Experienced User
FURRYe38 wrote:
When your 120 arrives, post the first 3 characters only of the serial number seen on the bottom sticker.
Usually also on the box. No need to even open it.
FYI, I've noticed that sometimes the numbers on the box can be covered over with other stickers that can't be removed coming from Amazon and having a used or refurb status. So if you find the box has a sticker or other stickers over this labeled box area, you'll need to visually look at the routers sticker. This should NOT be covered.
