kimweselowski
Nov 25, 2020Follower
I Phone 10 update
I phone 10 updated and now it won't connect to netgear wifi
michaelkenward
Nov 26, 2020Guru - Experienced User
Nothing has changed at the router end.
If the suggestion from plemans doesn't work, then you'll have to ask Apple for help. It broke your phone. There's not much that Netgear can do about it.
