gigabit123
Dec 29, 2023Aspirant
i recently bought a new router and it runs badly
the router says it is 4 gigabytes download speed but when i connect it with my LAN to my computer it maxes out at 50 mbps. Sometimes it runs at 100mbps (highest ive gotten). ive tried everything rest...
- Jun 06, 2024
guess what? i got the router back to 100mbps wohoo, i just was messing with the settings and i put the wireless 5g network to a higher channel and put it up to 3600mbps and it went back disclaimer i use ethernet
JJG1992
Dec 29, 2023Apprentice
4Gb is the wifi connection speed to wifi 6 enabled devices, the max download and upload speed will are limited by the 1Gb Wan/Lan ethernet ports so iff you pay for 1Gb down and up max you could get would be round about 945Mbps down and up over ethernet, wifi has other factors in place ie distance from router, location of router and other transmitting devices ( wireless landline phones, wireless soround sound speaker list goes on witch can cause wifi interference).
