gigabit123
Dec 29, 2023Aspirant
i recently bought a new router and it runs badly
the router says it is 4 gigabytes download speed but when i connect it with my LAN to my computer it maxes out at 50 mbps. Sometimes it runs at 100mbps (highest ive gotten). ive tried everything rest...
- Jun 06, 2024
guess what? i got the router back to 100mbps wohoo, i just was messing with the settings and i put the wireless 5g network to a higher channel and put it up to 3600mbps and it went back disclaimer i use ethernet
gigabit123
Yes i have the rax43 model.
Firmware version is : V1.0.12.120_2.0.83
I have a samsung phone
i have a 1 gigabyte ethernet cable
i dont know model but it is hardware version rax43
i use a auto channel
i have a 3008 cisco (maybe the cause because its old)
Dec 29, 2023Guru - Experienced User
I'd connect up a ethernet pc to the modem with out the router connected and speed test there.
The DPC3008 cable modem is up in age. Something to ask the ISP to see if there is something newer maybe or if you can buy your own. Again something to ask them about.
Be sure your using good quality LAN cable between the Modem and router. CAT6 cable is recommended.
Be sure to disable any MAC Address randomizers on phones and pads while at home:
https://community.netgear.com/t5/Nighthawk-App/NETGEAR-Mobile-Applications-and-Apple-Devices-FAQ/td-p/2220015/jump-to/first-unread-message
