gigabit123
Dec 29, 2023Aspirant
i recently bought a new router and it runs badly
the router says it is 4 gigabytes download speed but when i connect it with my LAN to my computer it maxes out at 50 mbps. Sometimes it runs at 100mbps (highest ive gotten). ive tried everything rest...
- Jun 06, 2024
guess what? i got the router back to 100mbps wohoo, i just was messing with the settings and i put the wireless 5g network to a higher channel and put it up to 3600mbps and it went back disclaimer i use ethernet
gigabit123
Jun 05, 2024Aspirant
hello.
i recently contacted this same community maybe like 2 weeks ago. the staff were horrible and werent helping + they didint even read what i said in the message or maybe they didint understand maybe they were from an foreign country with bad english we will never know.
Main thing
first when i started using this wifi router i had around 150-200mbps on my pc and i was happy, it wasnt the maximum but it was still good. then that 150-200mbps fell down to 100mbps and i felt like i can still live with that and didint think that was so bad.
but the when it fell down to 40mbps that was too much so i need help to bring it up to atleast 100mbps back.
READ IMPORTANT
here i will say all the things that the people asked and didint understand.
first dont ask about the modem thats not the problem and i know it 100% i have it tested with only the router.
second i know its a 4gb router but it can atleast get 1gb to my computer. (never even got to 1/4 way to 1gb)
i do use an ethernet cable and that cable can support more than 1gbs speed.
i have an samsung phone.
its at the latest firmware update.
Jun 05, 2024Guru - Experienced User
What wireless or ethernet adapter do you have connected on the PC?
Be sure any ethernet or wireless adapter drivers are up to date from there mfrs.
Test with a different PC or laptop to compare results.
Distances between the router and this PC?
1Gb ethernet doesn't support beyond 1Gb. If you have a mult gig ethernet adapter then that would. However this router doesn't support multi gig speeds, only 1Gb so you'll not see much past 900Mpbs ever.
Do you get to spec speeds with the ethernet connected PC connected directly to the back of the ISP modem?
https://www.increasebroadbandspeed.co.uk/realistic-speeds-wi-fi-5-and-wi-fi-6
https://www.wiisfi.com
https://support.google.com/fiber/answer/6250056#zippy=%2Cmobile-devices-wi-fi
