raphofcan
Jul 05, 2022Tutor
I updated the firmware and after the reboot the router does not accept the default login
Hi, i have the exact same problem. I updated the firmware and after the reboot the router does not accept the default login and password anymore. Please help me!
raphofcan
Sep 21, 2023Tutor
No, it never worked.
I have like 5 other router from different company that did that too among the lots of routers.
- FURRYe38Sep 22, 2023Guru - Experienced User
If other routers are doing same thing, then you might check your PC and browser for issues. Try a different PC and web browser.
- michaelkenwardSep 22, 2023Guru - Experienced User
Not sure what that is saying but if a lot of routers do the same thing that is a strong suggestion that the Netgear router is not the source of the problem.
Did you ever tell people what the modem/gateway/ONT is that sits between all of these routers and the Internet?
