Rp4000
Feb 20, 2020Aspirant
I want to ask about ax40 or ax80 before i buy it.
Ok I am in the market for a new router my router that I have been using since 2012 is getting old it's a dual band AC router. My question is how well do these new AX routers work with older devices b...
michaelkenward
Feb 22, 2020Guru - Experienced User
Is it just the age that concerns you? Or is there something on your system that doesn't work?
Has your Internet service changed in ways that suggest that you need something newer?
Rp4000 wrote:
I am really confused at if I should get a new ax router or just buy another AC router.
A good start would be to read the long list of messages about AX routers.
Rp4000
Feb 22, 2020Aspirant
The age of my devices most are ac/n devices . But I wanted a new ax type router but after reading alot of people complaints i had a lot of dought on buying a netgear . So how has the new firmware improved on the router or are there still alot of issues.
