carmartz
Jan 14, 2022Follower
I want to change my router wifi password from the default password.
The NightHawk Model#RAX4300 AX6 has a default password on the bottom of the device. I used it to setup the wifi connection to my tv, computers, etc. Is it a good practice to change the password? ...
Jan 14, 2022Guru - Experienced User
are you talking the admin password or the password for the wifi?
change admin:
https://kb.netgear.com/20026/How-do-I-change-the-admin-password-on-my-NETGEAR-router
change ssid/password:
https://kb.netgear.com/23439/How-do-I-change-my-NETGEAR-router-s-WiFi-password-or-network-name-SSID
ISPApp
Jan 15, 2022Tutor
Thank you.
