koa132435
Aug 01, 2022Star
I was able to make it to L2 after a few hours with L1
Same experience here. I was able to make it to L2 after a few hours with L1. Spent a few more hours collecting info and drawings. My problem is with AP mode and I am being asked to do tests for Netge...
Aug 01, 2022Guru - Experienced User
So might be more helpful if you let us know what NG product your referring too.
Maybe we can help you if you give more details to what your referring to and what problems your having.
koa132435
Aug 01, 2022Star
Sure, I got two RAX200s and configured both in AP mode. My needs call for the use of the 2.5 Gbps. Problem is that it seems the 2.5 Gbps port on the RAX200s is capped or throttle upload speed to ~500 Mbps. If I use one of the 1.0 Gbps ports then the upload speed is ~900 Mbps. I can repeat/duplicate this problem 100% of the times. Connectivity is below. I replaced the GS110EMX with a different multigig switch and same problem. No interference problem based on inSSIDer information. 2 different laptops, different brands and different WiFi Card same problem. Tested from iphone and same problem. Using 5ghz band. I am running the latest firmware and tested 2 previous fws same results.
Test 1
Laptop <--- 3 ft from RAX200 signal level -27dbm Tx/Rx wireless 2402 Mbps /2402 Mbps --->RAX200 Port 2.5 Gbps <--->GS110EMX <--> NAS/Local Speed Server Upload speed limited to ~500 Mbps / Download Speed ~900 Mbps
Test 2
Laptop <--- 3 ft from RAX200 signal level -27dbm Tx/Rx wireless 2402 Mbps /2402 Mbps --->RAX200 Port 1.0 Gbps <--->GS110EMX <--> NAS/Local Speed Server Upload speed ~900 Mbps / Download Speed ~900 Mbps
Apologies for hijacking the thread.
