Perkevz
Apr 30, 2024Tutor
Icloud not working
Currently trying to access icloud through their website. I have 2FA on and need a verification code whenever i try logging in. However every time i join my home network (wired/wireless) i can not get...
michaelkenward
May 01, 2024Guru - Experienced User
Who is "their"? Have you asked "them" for help?
What leads you to think that the router is involved in your problems?
Do you have problems with other websites?
If this is something iOS check this:
NETGEAR Mobile Applications and Apple Devices FAQ - NETGEAR Communities
2FA turned on where? iCloud?
- PerkevzMay 01, 2024Tutor“Their” would be apples iCloud website (www.iCloud.com) I have asked apple for help but they told me everything is fine from apples end. I don’t have any problems with any other website. 2FA is set up on my apple account that I am trying to log into. The issue is that when I request the verification code it gives me the error of “verification code can not be sent to this number at this time. Try again later” this error however only pops up if I am connected to my home network (wired or wireless).If I change network or use my phones mobile data it works perfectly fine. I also just upgraded to this router which is when I started having the issue.
- FURRYe38May 01, 2024Guru - Experienced User
You have the RAXE300?
What is the Mfr and model# of the Internet Service Providers modem/ONT the NG router is connected too?- PerkevzMay 01, 2024TutorYes I have the RAXE300
Firmware version 1.0.8.64_3
Ont: Alctel Lucent ONT I-211M-L
