Perkevz
Apr 30, 2024Tutor
Icloud not working
Currently trying to access icloud through their website. I have 2FA on and need a verification code whenever i try logging in. However every time i join my home network (wired/wireless) i can not get...
Perkevz
May 01, 2024Tutor
“Their” would be apples iCloud website (www.iCloud.com) I have asked apple for help but they told me everything is fine from apples end. I don’t have any problems with any other website. 2FA is set up on my apple account that I am trying to log into. The issue is that when I request the verification code it gives me the error of “verification code can not be sent to this number at this time. Try again later” this error however only pops up if I am connected to my home network (wired or wireless).If I change network or use my phones mobile data it works perfectly fine. I also just upgraded to this router which is when I started having the issue.
May 01, 2024Guru - Experienced User
You have the RAXE300?
- PerkevzMay 01, 2024TutorYes I have the RAXE300
Firmware version 1.0.8.64_3
Ont: Alctel Lucent ONT I-211M-L- FURRYe38May 01, 2024Guru - Experienced User
Is IPv6 enabled or disabled on the RAXE?
Try changing to custom DNS addresses, try Cloudfare, Quad9 or Google instead of ISP auto detected DNS.
Be sure to disable Any Mac Dddress randomizers on the device along with any cloud security features temporarily to check this. https://community.netgear.com/t5/Nighthawk-App/NETGEAR-Mobile-Applications-and-Apple-Devices-FAQ/td-p/2220015/jump-to/first-unread-message
Has a factory reset and setup from scratch with a wired PC and web browser?
https://kb.netgear.com/22697/How-do-I-install-my-NETGEAR-router-using-the-router-web-interface
If you have your prior wifi router, can put that back on line temporarily to see if this problem still appears or not.
- PerkevzMay 01, 2024TutorIPv6 is disabled
DNS changed to google but still having the issue, also tried cloudfare with no luck
Reset my netgear router and set up with a pc and rebooted ont. problem still happens.
Just tried my old router and issue does not occur.
