Retired_Member
Jan 17, 2024I'm getting freezing
Hi all,
Bought this router on the 4th Jan, using Christmas money. At first everything was good, great range and speed then after 4 days it all went wrong.
I'm getting freezing on Firmware 1.2.9.5...
- Retired_MemberJan 18, 2024
Done the reset and powered down.
Did the setup using a web browser- this is the first time not using the App
Armor, Access Controls and Traffic Meter all off.
Lets see how it goes, will report back...
Jan 17, 2024Guru - Experienced User
Ya, that seems like there trying to have you do a 30-30-30 reset on the router which in last case resort issues, can help bring a router back into operation. I would not think and don't think this would be helpful, however, I guess it wouldn't hurt to try. I guess try there method or try the 30-30-30 reset method. I guess if thats what they are asking, give it a go. Hoping someone knows more about this than we do.
After the router is back to ready, setup from scratch using the web a web browser:
https://kb.netgear.com/22697/How-do-I-install-my-NETGEAR-router-using-the-router-web-interface
I recommend setting the default DHCP IP address pool range to the following after applying and a factory reset: 192.168.#.100 to 192.168.#.200.
https://kb.netgear.com/24089/How-do-I-specify-the-pool-of-IP-addresses-assigned-by-my-Nighthawk-router
Be sure to not enable Armor, Access Controls, SPC or Traffic Meter afterwards.
Setup WiFi for your needs.
Then lets monitor and see if this happens again.
Retired_Member
Jan 18, 2024Done the reset and powered down.
- FURRYe38Jan 18, 2024Guru - Experienced User
Keep an eye on the CPU uasage value when you have time to take a peek.
- Retired_MemberJan 18, 2024CPU Load
9.60591%
Memory Usage(Used/Total)
377MB/869MB
Flash Usage(Used/Total)
233MB/512MB
Uptime
6 hrs - FURRYe38Jan 18, 2024Guru - Experienced User
Good data point.
Unless lots of devices are all online and doing lots of streaming or theres lots of downloading or uploading, I would presume and hope the CPU should keep in the single digit range. I put my RAX120 online yesterday in router mode and noticed the CPU usage with just one wired PC CPU was up at 37%. After being online for about 13 minutes, the CPU is now down to a single digit: CPU Load 4.92611%
Memory Usage(Used/Total) 342MB/869MB
Flash Usage(Used/Total) 233MB/512MB
Network Session(Active/Total) 247/65536
System Uptime 00:13:18Keep us posted on how it goes. Thank you.
- Retired_MemberJan 20, 2024
All good now, thanks for the help.
Proper reset and disabling Armor has fixed the router. Didn’t change anything else.
I obviously didn’t do a proper reset after the FW update-this is essential guys.
Great speeds over the whole house, kids happy with that.
Router Information with 30 devices connected, but nothing demanding.
CPU Load
3.75%
375MB/869MB
233MB/512MB
