MasterDabwalker's avatar
Jul 30, 2022
im having this problem now with a cm1000 and a rax 80
im having this problem now with a cm1000 and a rax 80 the rax 80 refuses to see the ethernet cord from the modem
1 Reply
  • FURRYe38's avatar
    What Cat# lan cable are you using between the modem and router?
    Be sure your using a good quality LAN cable between the modem and router. CAT6 is recommended.
    Has a power off for 1 minute then back ON with the ISP modem and router been performed since last update?
    Turn off and unplug modem.
    Turn on computers and rest of network.
